Pro 1.03: изменение настроек
Neptus
СообщениеДобавлено: Пт Дек 24, 2010 11:55 24.12.2010    Заголовок сообщения: Pro 1.03: изменение настроек Ответить с цитатой
Зашел в раздел "Настройки", поковырялся, поставил галочку "Индикатор в текстовых полях", нажал ОК и получил:
System.Data.SqlClient.SqlException: New transaction is not allowed because there are other threads running in the session.
в System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
в System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
в System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
в System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
в System.Data.SqlClient.TdsParser.TdsExecuteTransactionManagerRequest(Byte[] buffer, TransactionManagerRequestType request, String transactionName, TransactionManagerIsolationLevel isoLevel, Int32 timeout, SqlInternalTransaction transaction, TdsParserStateObject stateObj, Boolean isDelegateControlRequest)
в System.Data.SqlClient.SqlInternalConnectionTds.ExecuteTransactionYukon(TransactionRequest transactionRequest, String transactionName, IsolationLevel iso, SqlInternalTransaction internalTransaction, Boolean isDelegateControlRequest)
в System.Data.SqlClient.SqlInternalConnectionTds.ExecuteTransaction(TransactionRequest transactionRequest, String name, IsolationLevel iso, SqlInternalTransaction internalTransaction, Boolean isDelegateControlRequest)
в System.Data.SqlClient.SqlInternalConnection.BeginSqlTransaction(IsolationLevel iso, String transactionName)
в System.Data.SqlClient.SqlInternalConnection.BeginTransaction(IsolationLevel iso)
в System.Data.SqlClient.SqlConnection.BeginDbTransaction(IsolationLevel isolationLevel)
в System.Data.Common.DbConnection.BeginTransaction()
в #=qNLD27yaWqtJqeRK4lpIEqQ==.#=qzoj2P$MYStgXlP4fy9OxTQDm5RjezElL23bYMy_bJSs=(DbConnection& #=qlb3BCABdCvBymkO2aDEdcA==, String[] #=q2pDp2L0e2_s2$lMRKM6xZg==, Boolean #=q49tpAI5VteC$qZnECjr9sw==)
в #=qXg0sdR4PUNmTkoV1Qh0Jg5VO4c2qjfKKDiBHZS4Emts=.#=qyD_Zinv7694BMIeV1$cbFa3tXE1ihvfiyNamuvnAuxk=(String #=qEP9t0801qxG$58XTcIlFHA==, String #=qbUOkBfUdpiBzG545WYkelQ==, String #=q4d6eyVDrc8JuWfLRotGavQ==)
в #=qXg0sdR4PUNmTkoV1Qh0Jg5VO4c2qjfKKDiBHZS4Emts=.#=qKqcgWoRntaeVLQHn$JaNMQ==(String #=q6zKqhRoqde8kP8YUa7Gnog==, String #=qbEAbRDx2AAy5lM5JO63jCA==, String #=qfD8qlJZc7CJJtDQ6iUXodQ==)
в #=qXg0sdR4PUNmTkoV1Qh0Jg5VO4c2qjfKKDiBHZS4Emts=.#=qVc9_5rzmth1UtzjDiaG9ag==(String #=qMZkso1RE$r$k5kPGNUaLVw==, String #=qlF2$BIPc7FzkJ9OEQSmPXg==)
в #=qXg0sdR4PUNmTkoV1Qh0Jg5VO4c2qjfKKDiBHZS4Emts=.#=qNFPWL0NvDOd7Pp4jHpwvIaFBL6g_pqJrUlKgH1dYcas=()
в #=qjPB0_ey7UHRQfyOKf2aWohqwlku87GoI7fmb6l3m3Hg=.#=q7TG5hSCbqHBn9Yyy0s7Bk0jH2Qy7nXmw8pWYs84nklU=()
в #=qorvuaUWPugavK_NGK6ZL0fAWwdiFd6P6FXyajwlOWdw=.#=q3893fWbL6PQ2O7a9JGCuyYL9uuPRntaWrmYCuIEhnRM=(Object #=qxztIJKnqc$RKnrXdljKjww==, EventArgs #=qa9B7yUlMSQlPM7L06yFV6Q==)
Сохранить настройки эта гадость не дает, только отмена.
СообщениеДобавлено: Пт Дек 24, 2010 12:21 24.12.2010    Заголовок сообщения: Ответить с цитатой
Спасибо за баг-репорт, проблему изучаем.
А пока, чтобы включить отображение индикаторов в текстовых полях, можно в реестре в настройках программы (HKEY_CURRENT_USER\Software\PerfectSoft\PrintStore) добавить при необходимости параметр "ShowLanguage" и присвоить ему значение true.
СообщениеДобавлено: Пт Дек 24, 2010 12:29 24.12.2010    Заголовок сообщения: Ответить с цитатой
Ошибка найдена. Возникает только при работе с SQL базой. Исправление выпустим в понедельник, 27.12.
Neptus
СообщениеДобавлено: Пт Дек 24, 2010 12:33 24.12.2010    Заголовок сообщения: Ответить с цитатой
Понял. Мне собственно не горит, я так экспериментировал Rolling Eyes
СообщениеДобавлено: Пт Дек 24, 2010 12:46 24.12.2010    Заголовок сообщения: Ответить с цитатой
Там с SQL еще одна ошибка обнаружена, в обновлении шаблона названия оборудования. Из-за этого свежедобавленное оборудование нельзя переместить, например. Так что с новой версией мы все равно поторопимся.
Neptus
СообщениеДобавлено: Пт Дек 24, 2010 12:53 24.12.2010    Заголовок сообщения: Ответить с цитатой
Я тут еще кое что нашел:
Добавлял ремонт оборудования, одним днем отправка и получение из ремонта (сами справились Cool )
пытаюсь добавить а он -
в итоге после нажатия на ОК дважды получаю следующую строку -
Вроде все правильно, да не совсем.
Velavok
Разработчик
СообщениеДобавлено: Пт Дек 24, 2010 17:13 24.12.2010    Заголовок сообщения: Ответить с цитатой
Здравствуйте.
Ошибка найдена и исправлена.
В результате этой ошибки теряется информация, где находилось оборудования в момент его передачи в ремонт.
После обновления на новую версию, достаточно будет вызвать диалог изменения ремонта и нажать "ОК", для записей с отсутствующей информацией о местоположении. После этого данные о местоположении восстановятся.
P.S. Спасибо за оперативное сообщение об ошибках.
СообщениеДобавлено: Пн Дек 27, 2010 15:42 27.12.2010    Заголовок сообщения: Ответить с цитатой
Исправлено в 1.04.
Вот этот момент важен:
Neptus
СообщениеДобавлено: Пн Дек 27, 2010 15:56 27.12.2010    Заголовок сообщения: Ответить с цитатой
Вроде заработало ))
