0.98 Не могу получить ни одного отчета
Gres
СообщениеДобавлено: Пн Апр 19, 2010 8:16 19.04.2010    Заголовок сообщения: 0.98 Не могу получить ни одного отчета Ответить с цитатой
При попытке получить паспорт оборудования на экран выдается сообщение:
<<Unabled exception has occured in your application/ If you click Continue, the Application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Could not load file or assembly "Simulsoft.Controls.Win.Version=2010.1.700.0, Cuture=neutral, PublickKey Token=ebe6666cba 19647a" or one of its dependencies. Strong name validation failed. (Exception from HRESULT:0x8013141A).>>
После нажатия на кнопку Details в этом окне получаю вот такой дамп:
System.IO.FileLoadException: Could not load file or assembly 'Stimulsoft.Controls.Win, Version=2010.1.700.0, Culture=neutral, PublicKeyToken=ebe6666cba19647a' or one of its dependencies. Strong name validation failed. (Exception from HRESULT: 0x8013141A)
File name: 'Stimulsoft.Controls.Win, Version=2010.1.700.0, Culture=neutral, PublicKeyToken=ebe6666cba19647a' ---> System.Security.SecurityException: Strong name validation failed. (Exception from HRESULT: 0x8013141A)
The Zone of the assembly that failed was:
MyComputer
   at Stimulsoft.Report.Viewer.StiViewerControl..ctor(StiReport report, Boolean removeShortcuts)
   at Stimulsoft.Report.Viewer.StiViewerControl..ctor(StiReport report)
   at Stimulsoft.Report.Viewer.StiViewerForm.InitializeComponent(StiReport report)
   at Stimulsoft.Report.Viewer.StiViewerForm..ctor(StiReport report)
   at Stimulsoft.Report.Render.StiPreviewForm..ctor()
   at PrintStore.MenuBars.EquipmentsMenuDetailsReport_Click(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
Прошу простить за неумение вставить скриншот в сообщение.
Что у меня не так установлено?
СообщениеДобавлено: Пн Апр 19, 2010 9:19 19.04.2010    Заголовок сообщения: Ответить с цитатой
А винда какая?
СообщениеДобавлено: Пн Апр 19, 2010 11:43 19.04.2010    Заголовок сообщения: Ответить с цитатой
Для сообщения о таких ошибках скриншот и не нужен. Вообще на форуме у нас такая фича не работает, и скриншоты я вставляю сам вручную, поэтому присылайте их мне на почту (указана в руководстве к программе).
Теперь что касается самой ошибки. В версии 0.97 мы в очередной раз обновили генератор отчетов. Это сторонний компонент (stimulsoft.ru). Видимо, разработчики генератора задействовали какую-то тяжелую функциональность, потому что теперь для его работы требуется NET Framework 2.0 SP2 и не меньше. Это выяснено только что эмпирическим путем Wink. К сожалению, я давно не обновлял библиотеки MS NET FW на нашем сайте, поэтому NET Framework 2.0 SP2 надо скачать отсюда: http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=5b2c0358-915b-4eb5-9b1d-10e506da9d0f. Выбираете там сначала язык дистрибутива (повлияет на системные сообщения вроде баг-репортов, советую выбрать English), а затем внизу будут три файла для загрузки в соответствии с архитектурой вашей системы.
СообщениеДобавлено: Вт Апр 20, 2010 12:09 20.04.2010    Заголовок сообщения: Ответить с цитатой
Обновил раздел "Скачать" (http://printstore.ru/download/), теперь скачать NET FW 2.0 SP2 можно прямо с нашего сайта.
