Поймал глюки в версии 0.58...
Каспер
СообщениеДобавлено: Вт Июн 13, 2006 18:17 13.06.2006    Заголовок сообщения: Поймал глюки в версии 0.58... Ответить с цитатой
День добрый. Smile
При добавлении оборудования при нажатии 2 кнопки мыши выдаёт ошибку.
Нажимаю продолжить продалжает дальше. Ето первая ошибка.
System.InvalidCastException: Cast from type 'DBNull' to type 'String' is not valid.
at Microsoft.VisualBasic.CompilerServices.StringType.FromObject(Object Value)
at ExtCtrls.DBIO.GetStringArray(OleDbConnection& DBConn, String SQLString, String FieldName)
at ExtCtrls.ExtComboBoxB.Fill(String WherePart)
at ExtCtrls.ExtComboBoxB.Init(String DataSource, Boolean IsRequired, Int64 DialogID, Boolean MakeFill, String InsertedID, String InsertedColumn, Boolean UseNullValue)
at PrintStore.EquipmentDlg.Init()
at PrintStore.EquipmentDlg.Dialog_Load(Object sender, EventArgs e)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
PrintStore
Assembly Version: 0.55.2355.11929
Win32 Version: 0.55.2355.11929
CodeBase: file:///C:/ps-0.55/ps-0.54/PrintStore/PrintStore.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
ExtCtrls
Assembly Version: 1.0.2355.11926
Win32 Version: 1.0.2355.11926
CodeBase: file:///C:/ps-0.55/ps-0.54/PrintStore/ExtCtrls.DLL
SourceGrid2
Assembly Version: 2.2.0.0
Win32 Version: 2.2.0.0
CodeBase: file:///C:/ps-0.55/ps-0.54/PrintStore/SourceGrid2.DLL
SourceLibrary
Assembly Version: 1.2.3.0
Win32 Version: 1.2.3.1
CodeBase: file:///C:/ps-0.55/ps-0.54/PrintStore/SourceLibrary.DLL
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.6001.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Web.Services
CodeBase: file:///c:/windows/assembly/gac/system.web.services/1.0.5000.0__b03f5f7f11d50a3a/system.web.services.dll
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Web
CodeBase: file:///c:/windows/assembly/gac/system.web/1.0.5000.0__b03f5f7f11d50a3a/system.web.dll
edzwg2-p
Assembly Version: 0.0.0.0
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
enabled.
For example:
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Да и большая удача. При выборе отдела, стали появлятся ФИО ответственных. Smile))) Исчез поставщик. Ни кто не высвечивается. При нажатии на Плюс выдаёт ошибку...
System.Data.OleDb.OleDbException: Не был задан текст команды для командного объекта.
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at ExtCtrls.DBIO.GetLongArray(OleDbConnection& DBConn, String SQLString, String FieldName)
at ExtCtrls.ExtComboBoxB.AddButton_Click(Object sender, EventArgs e)
PrintStore
ExtCtrls
SourceGrid2
SourceLibrary
System.Web.Services
System.Web
edzwg2-p
System.Design
Accessibility
enabled.
For example:
[img][/img]
СообщениеДобавлено: Вт Июн 13, 2006 18:53 13.06.2006    Заголовок сообщения: Re: Поймал глюки в версии 0.58... Ответить с цитатой
Каспер писал(а):
При добавлении оборудования при нажатии 2 кнопки мыши выдаёт ошибку. Нажимаю продолжить продалжает дальше. Ето первая ошибка.
В смысле, не выводится контекстное меню, или что? В каком месте нажимается 2-я кнопка мыши?
Каспер писал(а):
Исчез поставщик. Никто не высвечивается. При нажатии на Плюс выдаёт ошибку...
Нужна информация об ОС и Framework.
Каспер
СообщениеДобавлено: Ср Июн 14, 2006 12:08 14.06.2006    Заголовок сообщения: Ответить с цитатой
Здравствуйте. Smile
При вводе нового одорудования нажимаю кнопку мышки квадратик
сининький высвечивается "Добавить экземпляр оборудования" нажимаю в выподает сообщение об ошибке.
Нажимаю кнопку продолжить и продолжаю работать. Rolling Eyes
PrintStore
ExtCtrls
SourceGrid2
SourceLibrary
System.Web.Services
System.Web
zfyf7sea
System.Design
Accessibility
enabled.
For example:
Microsoft NET Framework 1.1 SP1
WinXP SP2
В дальнейшем при выборе отделов в колонке отделы начинаю выбирать выдает ошибку.
System.InvalidOperationException: There is already an open DataReader associated with this Connection which must be closed first.
at PrintStore.EquipmentDlg.InputDepartment_SelectedIndexChanged(Object sender, EventArgs e)
at ExtCtrls.ExtComboBoxB.InputComboBox_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
at System.Windows.Forms.ComboBox.WndProc(Message& m)
PrintStore
ExtCtrls
SourceGrid2
SourceLibrary
System.Web.Services
System.Web
etntklt_
System.Design
Accessibility
enabled.
For example:
СообщениеДобавлено: Ср Июн 14, 2006 13:07 14.06.2006    Заголовок сообщения: Ответить с цитатой
Видимо, дело в некорректности или отсутствии каких-то данных. У меня ни на одной базе из доступных эти ошибки не появляются. Нельзя ли прислать мне вашу базу?
Каспер
СообщениеДобавлено: Ср Июн 14, 2006 13:23 14.06.2006    Заголовок сообщения: Ответить с цитатой
Здравствуйте. Smile
Без вопросов. На какой адрес слать. И "ps.udb" этот файл.
С уважением Каспер
СообщениеДобавлено: Ср Июн 14, 2006 16:10 14.06.2006    Заголовок сообщения: Ответить с цитатой
Нужен файл ps.udb. Мой адрес - michael[dog]printstore.ru
СообщениеДобавлено: Чт Июн 15, 2006 13:20 15.06.2006    Заголовок сообщения: Ответить с цитатой
Базу получил, спасибо. Все сразу стало ясно Very Happy .
Дело в том, что у каждого сотрудника есть т.н. сокращенное имя. Чтобы не писать везде "Иванов Иван Иванович", программа составляет сокращенное имя "Иванов И.И.", и в дальнейшем частенько его использует. Это происходит при добавлении/изменении информации о сотруднике. Так вот, в нескольких последних версиях (перед 0.58 ) составление сокр. имени не выполнялось. Из-за этого вместо таких имен в базе хранились пустые поля. Программа натыкалась на них и выдавала ошибку. Я сделал, чтобы в дальнейшем в похожей ситуации просто выводились бы пустые строки (и ошибка не возникала бы), а также добавил в программу пересчет всех сокр. имен при последующем обновлении.
Если ждать релиза не хочется, то проблему можно пофиксить вручную. Для этого нужно для каждого сотрудника вывести "Свойства", и просто нажать "ОК". После этого все глюки уйдут. Это актуально для версии 0.58. В более ранних может не помочь.
Из-за этого, кстати, были и проблемы с ответственными в диалоге оборудования.
Каспер
СообщениеДобавлено: Чт Июн 15, 2006 14:23 15.06.2006    Заголовок сообщения: Ответить с цитатой
День добрый. Smile
Базу получил, спасибо. Все сразу стало ясно .
Я и не сомневался, что разберёшся. Very Happy
Ошибки исчезли и имена стали появляться в отделах.!!! Wink
Это просто сказка. С сокращением имён классная идея и удобная. Главное, чтоб теперь в одном отделе не работало 10 Ивановых И.И. Rolling Eyes
Пофиксил вручную. Cool что я безрукий?(хотя если бы база была на 500-600 сотрудников я бы "обязручался" точно. Evil or Very Mad
Начну вбивать технику. Тут её уже большую часть вбил, но потом что-то меня ломануло и я всё это порешил.(что на меня нашло незнаю...накатило. Razz )
Лады, будем работать(совершенствовать) програму дальше. Laughing
Отчёты... и перезаправка тонеров\картриджей нужна(очень нужна) и чтоб стоимость там то же можно было указывать. По 4 картриджа иной раз на зарядку несу... Если бы сам заправлял, то IMHO институт бы давно встал. Rolling Eyes А так отчёт фин. дир. или глав буху, и усё в порядке.
Удачи всем нам.
СообщениеДобавлено: Чт Июн 15, 2006 16:06 15.06.2006    Заголовок сообщения: Ответить с цитатой
Можно было бы так и не торопиться Very Happy
Версия 0.59 уже доступна для загрузки.
Каспер
СообщениеДобавлено: Чт Июн 15, 2006 17:25 15.06.2006    Заголовок сообщения: Ответить с цитатой
Здравствуйте. Smile
Что ты, что? Покой нам только снится. Wink Злобные силы могут решить нас отпуска летнего, похода (покоя на природе, под цветущий сакурой), шашлыков и девушек. Вот и приходится работать как папа Карло. Razz
Теперь эти глюки пропали. Будем нарабатывать новые. Embarassed
Спасиб. Удачи нам.
