0.63: Ошибка при попытке получить отчёт
DJPavlo
СообщениеДобавлено: Чт Мар 01, 2007 11:12 01.03.2007    Заголовок сообщения: 0.63: Ошибка при попытке получить отчёт Ответить с цитатой
При попытке получить отчёт выдает следующую ошибку
System.NullReferenceException: Object reference not set to an instance of an object.
at PrintStore.MainForm.Menu_Items_in_Stores_Click(Object sender, EventArgs e)
at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
at System.Windows.Forms.MenuItem.MenuItemData.Execute()
at System.Windows.Forms.Command.Invoke()
at System.Windows.Forms.Command.DispatchID(Int32 id)
at System.Windows.Forms.Control.WmCommand(Message& m)
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
PrintStore
Assembly Version: 0.61.2581.15209
Win32 Version: 0.61.2581.15209
CodeBase: file:///D:/Programs/printstore/PrintStore.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42 (RTM.050727-4200)
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
ExtCtrls
Assembly Version: 1.0.2581.15209
Win32 Version: 1.0.2581.15209
CodeBase: file:///D:/Programs/printstore/ExtCtrls.DLL
SourceGrid2
Assembly Version: 2.2.0.0
Win32 Version: 2.2.0.0
CodeBase: file:///D:/Programs/printstore/SourceGrid2.DLL
System.Transactions
System.EnterpriseServices
System.Configuration
SourceLibrary
Assembly Version: 1.2.3.0
Win32 Version: 1.2.3.1
CodeBase: file:///D:/Programs/printstore/SourceLibrary.DLL
System.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Web.Services
p8a6pcrg
Stimulsoft.Report
Assembly Version: 1.60.0.0
Win32 Version: 1.60.0.0
CodeBase: file:///D:/Programs/printstore/Stimulsoft.Report.DLL
Stimulsoft.Base
CodeBase: file:///D:/Programs/printstore/Stimulsoft.Base.DLL
System.Web
Win32 Version: 2.0.50727.210 (QFE.050727-2100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Stimulsoft.Controls
CodeBase: file:///D:/Programs/printstore/Stimulsoft.Controls.DLL
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
enabled.
For example:
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
matrixbbs
СообщениеДобавлено: Пт Мар 02, 2007 8:02 02.03.2007    Заголовок сообщения: Ответить с цитатой
http://www.printstore.ru/forum/viewtopic.php?t=209
