1.47 Ошибка при работе с НРМ
На страницу 1, 2, 3, 4  След.
DIMMitriy
СообщениеДобавлено: Пт Сен 04, 2015 14:19 04.09.2015    Заголовок сообщения: 1.47 Ошибка при работе с НРМ Ответить с цитатой
Версия 1.47, база в udb
любые действия с номерными РМ
   в #=qBrnCMKXveOVaXEfbuA6WqlO5rjgelgxBW$rEujCqLrSFHHPda2lHwscdQ8XNmmQu.Paint(Graphics #=qxD17Y6$Y$GUah_RUfAp15Q==, Rectangle #=q8wIA3qDrA5T1dIdcGqoY7Q==, Rectangle #=qMS2ny4IAO8R2Uej1hq24UA==, Int32 #=qS$2lcVfXCuwEJL$7IxO5ig==, DataGridViewElementStates #=qhlQ2$gJFG2FfA96GStbClA==, Object #=qE9Z_T9qDi7q5q890LPXBxA==, Object #=qDcfwfSY$GsbHv8nEHyASHw==, String #=qzC4NkOUw5r3ctq1FodEa3Q==, DataGridViewCellStyle #=qURUlJJmLJ7kYWEAdd6ifDA==, DataGridViewAdvancedBorderStyle #=quXFJXAUdqQKMm9vMB5hSBmg5857ZJXIaw$j_lq4p_Cg=, DataGridViewPaintParts #=q996eHz1EWs3Vt4H1dMPA3g==)
   в System.Windows.Forms.DataGridViewCell.PaintWork(Graphics graphics, Rectangle clipBounds, Rectangle cellBounds, Int32 rowIndex, DataGridViewElementStates cellState, DataGridViewCellStyle cellStyle, DataGridViewAdvancedBorderStyle advancedBorderStyle, DataGridViewPaintParts paintParts)
   в System.Windows.Forms.DataGridViewRow.PaintCells(Graphics graphics, Rectangle clipBounds, Rectangle rowBounds, Int32 rowIndex, DataGridViewElementStates rowState, Boolean isFirstDisplayedRow, Boolean isLastVisibleRow, DataGridViewPaintParts paintParts)
   в System.Windows.Forms.DataGridViewRow.Paint(Graphics graphics, Rectangle clipBounds, Rectangle rowBounds, Int32 rowIndex, DataGridViewElementStates rowState, Boolean isFirstDisplayedRow, Boolean isLastVisibleRow)
   в System.Windows.Forms.DataGridView.PaintRows(Graphics g, Rectangle boundingRect, Rectangle clipRect, Boolean singleHorizontalBorderAdded)
   в System.Windows.Forms.DataGridView.PaintGrid(Graphics g, Rectangle gridBounds, Rectangle clipRect, Boolean singleVerticalBorderAdded, Boolean singleHorizontalBorderAdded)
   в System.Windows.Forms.DataGridView.OnPaint(PaintEventArgs e)
   в System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   в System.Windows.Forms.Control.WmPaint(Message& m)
   в System.Windows.Forms.DataGridView.WndProc(Message& m)
СообщениеДобавлено: Пт Сен 04, 2015 17:17 04.09.2015    Заголовок сообщения: Ответить с цитатой
Спасибо за баг-репорт. Воспроизвести ошибку не удается, возможно, она проявляется именно на ваших данных. Но есть предположения, в чем может быть дело. Уточните, у Вас версия Pro или обычная, я вышлю бета-версию с возможным исправлением ошибки для проверки.
DIMMitriy
СообщениеДобавлено: Пт Сен 04, 2015 17:18 04.09.2015    Заголовок сообщения: Ответить с цитатой
Версия обычная
СообщениеДобавлено: Пт Сен 04, 2015 17:54 04.09.2015    Заголовок сообщения: Ответить с цитатой
Отправил на почту ссылку на бета-версию, просьба проверить и отписаться здесь.
DIMMitriy
СообщениеДобавлено: Пт Сен 04, 2015 18:00 04.09.2015    Заголовок сообщения: Ответить с цитатой
Таже ошибка Crying or Very sad
СообщениеДобавлено: Пт Сен 04, 2015 18:16 04.09.2015    Заголовок сообщения: Ответить с цитатой
Странно. А на каком, например, действии возникает ошибка? И в какой именно момент?
DIMMitriy
СообщениеДобавлено: Пт Сен 04, 2015 18:17 04.09.2015    Заголовок сообщения: Ответить с цитатой
Могу отправить базу по почте
СообщениеДобавлено: Пт Сен 04, 2015 18:20 04.09.2015    Заголовок сообщения: Ответить с цитатой
Да, это будет лучше всего
DIMMitriy
СообщениеДобавлено: Пт Сен 04, 2015 18:30 04.09.2015    Заголовок сообщения: Ответить с цитатой
Отправил
СообщениеДобавлено: Пт Сен 04, 2015 18:37 04.09.2015    Заголовок сообщения: Ответить с цитатой
Базу получил. Попробовал ставить НРМ в оборудование, перемещать на другие склады, удалять записи из истории - ошибки нет. Причем, как в текущей версии с некоторыми исправлениями, так и в оригинальной 1.47.
Ошибка появилась именно в 1.47? Какая ОС, все ли обновления стоят? Какие действия точно приводят к ошибке?
DIMMitriy
СообщениеДобавлено: Пт Сен 04, 2015 18:39 04.09.2015    Заголовок сообщения: Ответить с цитатой
База работает по сети. Ошибка на win8.1 (x64) и на 7 (x64)
DIMMitriy
СообщениеДобавлено: Пн Сен 07, 2015 10:49 07.09.2015    Заголовок сообщения: Ответить с цитатой
Как то возможно узнать причину этой ошибки? База ведется уже много лет - не хочется ее потерять
СообщениеДобавлено: Пн Сен 07, 2015 10:52 07.09.2015    Заголовок сообщения: Ответить с цитатой
Michael писал(а):
Ошибка появилась именно в 1.47? Какие действия точно приводят к ошибке?
DIMMitriy
СообщениеДобавлено: Пн Сен 07, 2015 11:02 07.09.2015    Заголовок сообщения: Ответить с цитатой
Запуская программу
Отчеты -> Ном. рас. мат. -> любой из отчетов
СообщениеДобавлено: Пн Сен 07, 2015 11:17 07.09.2015    Заголовок сообщения: Ответить с цитатой
Это же ведь уже другая ошибка? С отчетами это будет ценная информация, потому что у других пользователей с такой ошибкой не остается это окно, сразу исчезает. Нажмите кнопку "Сведения" и скопируйте текст сюда. Далее тема будет разделена, т.к. каждая ошибка изучается и исправляется отдельно.
По первой ошибке все же прошу уточнить , что имеется в виду под "любые действия с номерными РМ".
Последний раз редактировалось: Michael (Пн Сен 07, 2015 12:02 07.09.2015), всего редактировалось 1 раз
Страница 1 из 4
