0.87 пора купить.даёт ошибку.
Каспер
СообщениеДобавлено: Ср Дек 16, 2009 16:37 16.12.2009    Заголовок сообщения: 0.87 пора купить.даёт ошибку. Ответить с цитатой
Здравствуйте Very Happy
При выполнении отчёты/пора купить
выдаёт ошибку.
System.InvalidOperationException: This operation cannot be performed while an auto-filled column is being resized.
at System.Windows.Forms.DataGridView.OnBandThicknessChanging()
at System.Windows.Forms.DataGridViewBand.set_Thickness(Int32 value)
at System.Windows.Forms.DataGridViewColumn.set_Width(Int32 value)
at PrintStore.NeedToBuyDlg.SetDGVColumnsAutoSize()
at PrintStore.NeedToBuyDlg.SetDGVColumnsWidth()
at PrintStore.NeedToBuyDlg.DGV_ColumnWidthChanged(Object sender, DataGridViewColumnEventArgs e)
at System.Windows.Forms.DataGridView.OnColumnWidthChanged(DataGridViewColumnEventArgs e)
at System.Windows.Forms.DataGridView.OnBandThicknessChanged(DataGridViewBand dataGridViewBand)
at System.Windows.Forms.DataGridView.AdjustFillingColumns()
at System.Windows.Forms.DataGridView.ComputeLayout()
at System.Windows.Forms.DataGridView.PerformLayoutPrivate(Boolean useRowShortcut, Boolean computeVisibleRows, Boolean invalidInAdjustFillingColumns, Boolean repositionEditingControl)
at System.Windows.Forms.DataGridView.OnLayout(LayoutEventArgs e)
at System.Windows.Forms.Control.PerformLayout(LayoutEventArgs args)
at System.Windows.Forms.Control.System.Windows.Forms.Layout.IArrangedElement.PerformLayout(IArrangedElement affectedElement, String affectedProperty)
at System.Windows.Forms.Layout.LayoutTransaction.DoLayout(IArrangedElement elementToLayout, IArrangedElement elementCausingLayout, String property)
at System.Windows.Forms.Control.OnResize(EventArgs e)
at System.Windows.Forms.DataGridView.OnResize(EventArgs e)
at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
at System.Windows.Forms.Control.UpdateBounds()
at System.Windows.Forms.Control.WmWindowPosChanged(Message& m)
at System.Windows.Forms.DataGridView.WndProc(Message& m)
СообщениеДобавлено: Ср Дек 16, 2009 17:47 16.12.2009    Заголовок сообщения: Ответить с цитатой
Спасибо за баг-репорт. Пока не очень понятно, в чем дело. Будем разбираться.
СообщениеДобавлено: Пт Дек 18, 2009 17:03 18.12.2009    Заголовок сообщения: Ответить с цитатой
В 0.88 в "Пора купить" меняли некоторые вещи, глянь как там, может заработало?
СообщениеДобавлено: Сб Дек 19, 2009 10:01 19.12.2009    Заголовок сообщения: Ответить с цитатой
Я же говорю где-то уже было Laughing http://printstore.ru/forum/viewtopic.php?t=658
Каспер
СообщениеДобавлено: Вт Дек 22, 2009 18:55 22.12.2009    Заголовок сообщения: Ответить с цитатой
Не всё так же. Shocked
Каспер
СообщениеДобавлено: Ср Дек 30, 2009 16:22 30.12.2009    Заголовок сообщения: Ответить с цитатой
В новой версии 0.89 всё так же даёт ошибку. Cool
СообщениеДобавлено: Ср Дек 30, 2009 19:54 30.12.2009    Заголовок сообщения: Ответить с цитатой
С этой ошибкой не так все просто. У нас она ни под каким соусом не воспроизводится Confused. То есть надо детально изучать код. В этом году уже не успевали, но в следующем обязательно с этой ошибкой разберемся Very Happy.
Каспер
СообщениеДобавлено: Ср Дек 30, 2009 22:36 30.12.2009    Заголовок сообщения: Ответить с цитатой
Спасибо. Я думаю, может это моя ошибка...(ну типа локальная по базе) Embarassed Я использую программу пока и без этой функции. Wink
Alek
СообщениеДобавлено: Пн Янв 11, 2010 7:35 11.01.2010    Заголовок сообщения: Ответить с цитатой
День добрый. Большое спасибо разработчикам за программу Smile
Пользуюсь уже 3 месяца - красота Smile
После обновлении с 0.88 на 0.89, про попытке выполнить "Пора купить" стала выскакивать ошибка
Код:
System.IndexOutOfRangeException: Индекс находился вне границ массива.
   в PrintStore.NeedToBuyDlg.SetSellers()
   в PrintStore.NeedToBuyDlg.LoadFields()
   в PrintStore.NeedToBuyDlg.Dialog_Load(Object sender, EventArgs e)
Хотя если нажать "Продолжить" программа работает нормально, заказ формируется и добавляется в "заказы".
Система: Win XP SP 3, Net Framework 2 SP2, 3 SP2, 3.5 SP1
База расположена на файл сервере ("DBPath"="\\\\fs\\PrintStore\\ps.udb")
Velavok
Разработчик
СообщениеДобавлено: Вт Янв 12, 2010 0:35 12.01.2010    Заголовок сообщения: Ответить с цитатой
Для нас очень важно, что пользователи ценят наш труд. Ошибка найдена и исправлена. Спасибо за баг-репорт.
СообщениеДобавлено: Вт Янв 26, 2010 22:10 26.01.2010    Заголовок сообщения: Ответить с цитатой
Вроде все описанные здесь ошибки найдены и исправлены в 0.90. Проверяйте.
